View the Mesh Group
Configure Message Digest (MD) 5 authentication to secure control messages on the TCP connection between MSDP peers.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  1. In the navigation pane, expand Configuration > IP.
  2. Select MSDP.
  3. Select the Mesh Group tab.
Mesh Group Field Descriptions
Use the data in the following table to use the Mesh Group tab.
Name
Description
Name
Specifies the mesh group ID; the name of the mesh group from 1-64 characters.
PeerAddress
Specifies the IP address of the MSDP router that is the peer.
